TwinTurbo.NET: Nissan 300ZX forum - Check timing belt is on correctly, try using a charger
ttsmokin
on April 23, 2013 at 12:03 AM
Re: Did you hook up a battery charger?
posted by longlivetheZ
on April 22, 2013 at 07:06 PM
If everything else checks out, try adding a teaspoon of oil to each cyl and re-test. If compression jumps up, the rings/cylinders are worn.
What do we think?
longlivetheZ
16:38:18 04/21/13
Yuup, interesting that one bank is much lower
ttsmokin
16:43:34 04/21/13
Agree.. Check Belt Timing.. (n/m)
Cjw3
18:12:58 04/21/13
Tanley
18:21:28 04/21/13
Low readings by the 2nd cyl tested is terrible, bad batt or
ttsmokin
18:53:17 04/21/13
That was my experience.
Tanley
04:51:40 04/22/13
longlivetheZ
19:06:36 04/22/13
Check timing belt is on correctly, try using a charger -
ttsmokin
00:03:56 04/23/13
Re: What do we think?
ZTom
18:37:21 04/22/13
longlivetheZ
19:26:08 04/22/13
longlivetheZ
19:28:24 04/22/13
